Grapple Front boom and grapple?
/ Front boom and grapple? #1
Horse
Wyoming
John Deere 4410 12x12 E-Power-Reverser
Mornin all. Anybody seen or heard of a front boom attachment? I will be stacking log walls on my barn and was thinking a Boom and grapple arrangement would be better than just pallet forks. I have a 4410 ordered with a 430 FEL. Anybody out there maybe worked around the timber industry and know of anything? /forums/images/graemlins/confused.gif
Thanks /forums/images/graemlins/tongue.gif
/ Front boom and grapple? #2
I have seen pictures of a 3-pt boom pole modified with a quick attach plate for a bobtach or ATI quick attach for use on a FEL also equipped with the bobtach or ATI systems. If you weld, you could probably make one to fit the JD quick attach system on the FEL. Getting a log dangling at the end of the boom pole, however, would put a lot of leverage on your FEL. You would need a big counterweight on the 3-pt, and may max out the hydraulics on your FEL.
You can also probably buy a grapple to fit the JD quick attach system on the FEL. You would need an additional remote hydraulic setup to operate the grapple.
Finally, a 4-in-1 bucket would grip logs, allowing you to lift them as high as your FEL would lift -- which may not be quite enough for a wall on a barn. You would need the same remote that you would for a grapple.
Good luck on your search. These folks on TBN have a lot of good ideas and experience. I am sure more will chime in /forums/images/graemlins/grin.gif.
/ Front boom and grapple? #3
Horse,
If a backhoe is feasible it could be used to raise logs to the height that a backhoe would dig. I have been very successful handling logs with precision by using a chain around the bucket hinges on my backhoe and logging tongs. Some trial and error on placement of the tongs is necessary to reach a balance point, then the backhoe is used as a crain. On milled logs, and railway ties, I have used the chain around the bucket hooked to the largest screw eye I can find placed at the balance point with equally satisfactory results. The backhoe would allow placement of logs significantly higher than the FEL/pallet fork option and the backhoe would be useful for many other tasks.
Good Luck,
Bill
/ Front boom and grapple? #4
Hi,
I you take a look at the "Spencer's pole barn project" you can see some pictures of what he did along those lines.
It is in the Projects forum...sorry I did not think to find the link before starting to type this, but you will find it easily I think...
/ Front boom and grapple? #6
</font><font color="blue" class="small">( You can also probably buy a grapple to fit the JD quick attach system on the FEL. You would need an additional remote hydraulic setup to operate the grapple. )</font>
I responded in another thread, but I have this grapple http://www.borgford.com/grapple.htm . It works great, and they custom build them for your tractor. In my case it bolts right up to the standard JD bucket attach mechanism so it takes no more than 2-3 minutes to change between the grapple and the bucket. You do need the extra front hydraulics (third SCV) to operate the grapple or a 4-in-1 bucket.
Thanks to all. Good info here on TBN for sure. Looks to me like a simple boom could work for me and it would increase reach as well.
Thanks again
2009 Wilson Hopper Bottom Trailer (A66285)
2009 Wilson Hopper...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
New/Unused ATS Lifting Motor (A65583)
New/Unused ATS...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
