Front Axles
/ Front Axles #11
Is a large seal I can't remember the numbers on the seal .I just installed mine today.
/ Front Axles #12
Does the bearing wobble take out the seal very fast? I have a 2000BD that has a badly leaking left knuckle seal that I was going to replace this weekend. I only have the knuckle seal and don't want to ruin it if I need to do more work later.
Jerry
/ Front Axles #13
In general, If you have a bad bearing..the associated seal won't live long... that's the prime reason you see leaky water pumps a few weeks before your fan flies into your radiator..
Soundguy
/ Front Axles #14
Don't forget, these bearings also locate the gears. All you need to do is catch a tooth and then you'll have a broken gear. Some of these front end gears are irreplaceable. Would I put off the repair? Heck no!
/ Front Axles #15
All I know at this point is that one knuckle seal leaks pretty good. Do they go bad without a bearing problem? How do I tell if I need to do additional repairs besides seeing how long my $30 seal lasts /forums/images/graemlins/grin.gif
/ Front Axles #16
With mine it was pretty obvious. The bearings fell out of the race when I took the king pin out. Because of the way the knuckles are positioned, it's easy for dirt to get caught and wear on the seal. A new seal may be all that you need. But you won't know until you take it apart.
FYI-some of these bearings can be preloaded. You might just need to snug them up a bit to get rid of any slop. The roll pin was missing from the castle nut that tightened my wheel bearing. With the extra slop it didn't take long for the seal to fail. Depending on how long it would have gone, the damage could have been destroyed gears, galled bearings from the lack of lube to the nut falling off and me actually loosing the wheel! Although these axle look real complex, they're actually not that bad to take apart. Just do one side at a time and lay out the parts in order so reassembly will be easier. I was able to get all the bearings and seals directly from a bearing supplier. I replaced every seal, a couple of speedy sleeves for the wheel seals and a couple bearings for $100.
/ Front Axles #17
</font><font color="blue" class="small">( I was wondering about something... I noticed that the housing has a little upward and downward play in it because where the pitman arm off the steering attaches to the axle housing it doesn't draw down tight to the shaft between the arm and axle housing. Could this be an issue? )</font>
If you have enough play, the lower housing can drop on uneven ground resulting in chipping or breaking gear teeth. My 1500D had some worn teeth from the up and down slop. Fixed it by replacing the old worn washer with two new washers and adding a thicker bolt to steering arm to snug it tight. Seem to do the trick.
/ Front Axles
VT, Thanks for that information. When I pull it back apart I'll address this. Thank you all again for the feed-back.
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Ford Pickup Truck Bed (A59230)
Ford Pickup Truck...
