Freinds home built machinery
/ Freinds home built machinery #1
Taylortractornut
Elite Member
Iuka Mississippi USA
3550 Fard Backhoe and a 1948 Farmall Cub,
Ive got 2 freinds here that are good at building there own machinery. I work with both of them alot in there project and get to see the end results. The first machine is my distant kin Jimmy Lambert He built a TLB from an old Datsun car and the rearend out of a Moline tractor. It was made in stages First he got to drawing plans to make a tractor then wanted a loader then figured lets build a whole backhoe. His dad told him it wasnt possible but Jimmy told him somebody made the first one. Its a little worker He rear boom is under going a rebuild after a mishap with a stump. Allthe booms are from sheet stock in there homemade brake press. He second machine im gonna show is a another freind by the name of Jimmy Wells that built his own 4wheel drive and steering loader. its a bit bigg than and average Bobcat and has 2 transfer cases and an automatic transmission.
The backhoe has a little over180 degree swing. and the small bucket is the trade off for the long boom.
Heres the loader and front view of the loader linkage
Another side shot
Jimmy Well's $wheel drive and steer loader
/ Freinds home built machinery #6
Maybe it's time to come up with a Junkyard Wars team from TBN. Give me wrought'n Harv, this guy and JM3 and we're ready to go!/w3tcompact/icons/laugh.gif
/ Freinds home built machinery #7
<font color=blue>Give me wrought'n Harv, this guy and JM3 and we're ready to go!</font color=blue>
Now that sounds like a winning team. /w3tcompact/icons/laugh.gif
/ Freinds home built machinery #8
They are great, I love home made stuff, thanks for the pics.
/ Freinds home built machinery #9
Sometimes creating something useful from junk and scraps can be so rewarding, /w3tcompact/icons/cool.gif especially if you're into saving money as well. I know for myself, I sometimes enjoy the fabricating more than the actual using of the finish product. I can only compare it to vacationing and travel, the getting there is as much fun as being there. Great Pics., thanks for sharing /w3tcompact/icons/clever.gif ....RayBee
The fella that built the little loader narrowed down the front axles out of a Chevy C5 blazer by cutting the housing down on the long side and puttin another short side axle in its place. Hes building a larger rear steering loader with a 1 1/4 yard bucket. Whats amazing it the fella is in a wheelchair. It takes him a bit to make these machines but well worth the time spent.
My cousin that built the Backhoe has repaired the boom section and is using it again. He made a little compact tractor with a loader a few weeks ago ill try to get a few pics of it. In one of the pics if youll look in the background of the mans house you can see on the porch his yellow homebuilt 4 wheeler its got a 1400 cc nissan motor and transmission. and is 4 wheel drive with and all sheet metal body and independent front suspension.
/ Freinds home built machinery #11
Thanks for the pictures. I really like seeing how home-made inovation works!!
/ Freinds home built machinery #12
Was this guy working off of a detailed design or did he design it as he put it together?
Great Pictures btw.
Both builders were building on trial and error. The man with the loader designed his arms and mounts like similar to a skid steer. My cousin with the backhoe just started building lol
Interesting that you mentioned shoes Jimmy that built the loader is in a wheel chair partially. He had 2 bad car accidents a few years ago. The way he builds is to not make a part or assembly too cumbersome to handle from a wheel chair. Hen he gets positioned he can prop himself up to weld. Hes been thinking of building a hydraulic lift,boom to manuver his chair around the shop.
/ Freinds home built machinery #16
does that little one (skid steer) use standard car/truck type steering or is it tank skid steer type steering? I see the steering wheel, but I'm wondering if it is a 4 wheel steer and skid steer (opposit rotating wheel dirrection on opposite side type thing?)
ok tell them looks good though! that is comming from a pro fabricator!
Mark M /forums/images/graemlins/cool.gif
Mark Jimmy just linked the 2 steering axles together with a draglink added from one axle to another. He said it wasntfun at first bacaus he steered the rear axle into a ditch he was digging. I told him about how ome of the roughterrain cranes i drive are like that when ou want to steer the rear axle its linked like that but it also has a cylinder in the middle of the link to make the rear wheels either independant or locked on an angle to ccrabsteer with the front axle. With the allwheel steer it has a short turn radius and wont maul the turf like a skid loader.
/ Freinds home built machinery #18
TTN Yes tell him it's awesome. Some questions. What did he use to power it?and how does it connect through the transfer cases? did heshorten and reweld the axles or just get new ones? I'd like to build one to feed hay in my narrow mangers but I'am not sure I can get the front ends and all the steel cheap enough to make it. One more question, does it have positrac or does it spin out if one wheel lifts. Can he make rough measurements to send me.
Its got a positrac in the rear diff and a limited slip in the front. It digs out of his red clay banks as good as a Bobcat or swinger loader. He had a smaller version planned ith Suzuki Samuria axles that he had narrowed but he sold them to finance a bigger loader. Ithink he used the minvan transmission as well as the motor. The axles he shrtened the hosing done on the long side down to a short side leng then used new short sided live axles he mave have also gotten a few out of the junkyard to. He tells me he could have gone narrower but he didnt want to have to cut the live axles in the center and realign them. It took him a while to scrounge all the parts but took 3 weeks to build. you could use stock xles out from under the fronts of samurai's if you dont pan to commercially use it. Jimmy overbuilds things alot. He's changed a few things since these pics were taken. For most of his hard piping he uses 1/2 inch black pipe. It saves alot of cash for some of the long lines that dont have to be flexible. With the smaller samurai axles a man could possibly run a loader off a low horse engine like a vw or a 16 horse Kohler. Ill try to take some digital photos of the machine and some measurements this week after work
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65054)
2001...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2010 UE Manufacturing Armada 1000HP Single Pump Tri Axle Frac Blender Trailer (A64194)
2010 UE...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
