freedom_fighter
/ freedom_fighter #1
freedom_fighter
Folks;
I'm a "newbe" here, looks like a GREAT site! My question, does anybody have any experiance with a Kubota GCK60-BX Grasscatcher attachment for B-Series Kubotas, (specificly a B 2710) ? I'm curious as to how well it works;(probabbly great, as most Kubota attachments), as well as how quick it is to attach/remove. Also how durable is (and exactly HOW ) is the attachment made to the deck. How much does it limit mowing close to the right side? How easy is it to empty the bags? What is their rough capacity? ANY general feed-back as well, would be greatly appreciated!
Thanks !
JR
/ freedom_fighter #2
I saw one of these the other day on an earlier vintage B series. Looked pretty similar to the model I have on my tractor. Looking at your request, it turns out you're asking about he EXACT model that is on my tractor...the GCK60-BX.
The bagger works quite well. You really need to run it at WOT to be effective in sucking up everything, especially if the grass is a little heavier, wetter, clumpier, or whatever-ier. I used to run it at slightly less than WOT and had real issues with it clogging.
I've had real issues with the shear pin, as well. It seems I have it licked since I started RETAINING the roll pins with a bent screw or coat hanger or something. I've had the same pin in there for 3 mows now and it still seems OK. On my worst days, I've had to replace the shear pin 3 times in a single mow, but that was before I started figuring out what the culpret was...the pin was actually sliding out of the holes. I used bolts for a while, but they just don't have enough 'give' to work with the shock load of sucking up a hunk of tree.
Regarding capacity, it is listed as 10 bushels. It is tough to know when it is full, but when you hit that sweet spot, it holds a LOT of material. It is packed down quite firmly and there isn't a speck of un-used space. They are very easy to unload, but can get a little heavy if you fill them up...especially the one on the left of the tractor...it fills first. Can probably get to 40 or 50# with wet grass. But the top is completely "open", so one good shake and ALL the material comes straight out...none of that shaking up and down crap that you do with lesser baggers.
The boot that gets mounted to the MMM discharge definitely cuts down on how closely you can cut on the right side (by less than a foot), but it isn't that big of a deal to go the right way around and edge with the left side...I can cut within an inch of most things with that side of the deck.
The unit is very durable...I backed mine into a tree already and had it all fixed in under an hour. Pretty heavy metal...the plastic hood deformed pretty bad, but it shaped back when I bent the "rim" into shape...looks good as new now.
The downside to the unit is that it is a pain to install. My biggest problem is lining up the top link in the EXACT right position to put in the pin. I have it on casters, which helps attaching the lower links. And I use a jack to put in the top link, but in all, it takes me about 8 to 10 minutes to install...slightly less to take off. 8 to 10 minutes doesn't sound like a lot, but that is as much time as it takes to remove the BH, remove the FEL, and mount the MMM. Relatively, that is a lot of time devoted to the bagger.
The attachment to the deck is by a big plastic boot that slides under the side chute...there is a special braket that comes with the whole thing. It also comes with a heavy spiral-wound 8" flexible pipe thing that carries the material from the deck to the impeller.
Hope that gets you started...look under the BX lineup on the Kubota web-site for a better idea of specs. Pretty bad picture, though. That model is slightly newer, but the specs are about the same.
/ freedom_fighter #3
According to the Kubota website the correct grass catcher for your B2710 is GCK60-24B. This is the same as my B7500. The reason I am pointing this out is that I have this model grass catcher that I would sell.
Where are you located? I am in Denison, TX
Daniel
/ freedom_fighter
Keith; Thanks ever so much for the informative reply! It was very helpfull. Given the generally high quality of Kubota products, I was surprised to learn of the shear pin problems; have you a good dealer to discuss the problem with? At any rate it would appear it was merely an engineering oversight, rather than an serious error. I have been in construction nearly 40 years, have been exposed to or used, just about every thing out there; and Kubota is definatly the "Real Thing". I'm still amazes at the quality, and attention to detail Kubota engineers into their products. I would at least for now, probably only "Seasonal Mount" the grasscatcher, removing it, along with the MMM Deck, at seasons end, so 8-10 minutes dosent sound bad at all ! I've had one response that said "According to the Kubota website the correct grass catcher for your B2710 is GCK60-24B." Hmmm. I'm not real computer savvy, I've looked at the "Kubota website" and cant find a reference at all to a grass-catcher, (much less, actual model #'s ) for my B-2710. Just HOW does one find that info? I've found a fellow with a solid used unit with the suffix BX, I know both machines have Cat 1 3-point hitches, along with rear PTOs. My B series has some 35 % more HP. Given the prefix in the Mod. # is the same, I would assume the only real difference in the units, defined by the suffix, is the deck/blower attachment, which, hopefully would be available from Kubota. If you might have a web addy for more info, I sure would appreciate it! I will be in the market for a "Root or Rock Rake" tined loader bucket for my LA402 loader. I intend to add a grapple, (hopefully dbl, with sep. controls) for the firewood processing my sons and I do as well. We welded a "floating" chain clevis in the center top I/s of the std. ldr bucket, to attach our big skidding tongs, and through ten + lg hard wood trees from last winter's tornado, in 1-2 ft of snow, it easily cut processing time and labor, a good 60%. We've used an old Case 410 TLB, with a G-148 Gas 4 cyl eng, for the same purpose for years, (it was actually too big, and clumsy for the close work we usually do.) I was surprised at how much utility I got from the Std Ldr bucket, as well as the AWD pushing power in snow. I drive for a Ready-Mix, sand & Gravel, & Roll-off (dumpster) co; I "borrow" a 20 Cu Yd box and set/pick up the unit on my "own" time. I swing open the full width door, have steel ramps into the box, (only a 10-12 in rise) & start driving right in the box with the "Kubota Dragon", backing my way out from the closed end. The machine fits right in the dumpster box, for transport to job-site as well.My old TLB would never fit inside. The rake, or tined bucket would reduce sod, bark and trash accumilation, & the Grapple would help in handling cumbersome Lg "Rounds", some of which approach nearly 4 ft in diameter. I will eventually cut down, an old hydro-turn PU truck snowplow, to about 6 ft in with, for winter plow duty. I intend to use the controll valves from the bucket grapples to actuate the hyd angling. I've looked at a couple of "Quick tach" skid-Ldr style options for the loader, and buckets, pallet forks, etc. For the other end of the machine I want good solid tiller,(probably counter rotating tines), a ph augur, a box blade with scarifier, a chipper-shredder for brush, (I'm looking at a 5 ft grass seeder, now), power rake? Who knows? Of course, the holy-grail; a B-Hoe. I can see now to utilize the full versitility of this amazing little machine, one could easily spend as much or more for impliments as the tractor itself! Sorry, I'm rambling, but I can't help it-such an amazing machine...... At any rate, thanks again for the detailed, knowledgable, informative, reply. I found it very helpfull !
JR
Please forgive my spelling errors, I haven't the time to download the "spell-ck" feature.
213088 (A64276)
213088 (A64276)
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
2022 EZ-GO ELITE...
KMC 14' FIELD CULTIVATOR (A64278)
KMC 14' FIELD...
