Free air?
   / Free air? #71
I just need to take a picture of it to prove that I actually did install it.
I believe you installed it, but a picture would help me figure out how to do this. :) One of those things I've always meant to do.
   / Free air? #72
I think where Gary did better than I did is when he got brass fittings. I used galvanized pipe for the el and nipple which may be the difference in the height. Of course I did use a quarter turn valve.
   / Free air? #73
   / Free air? #74
If you used a 90 ell (female threads on both ends) then you have added about an inch or more to the total drop due to the short pipe nipple needed. I know they make street ells (male on one end x female on the other) in all materials but finding them may be a challenge. The reason I went with brass is because Lowes didn't have any steel fitting in 1/4". The benefit of course is that I wont get any corrosion like I would with black iron, but galvanized would have worked fine IF Lowes had it in stock. Anyway, I got lucky with the fittings as the size was correct and the dimensions worked put just right. A 3.5" nipple would have put the valve a bit further out which would have been a bit better than the 2.5" I installed but it is functional as it is.
   / Free air? #75
A couple of photos of the finished product would be nice if I could get them to upload. I don't know what has happened but recently I have been unable to upload any photos, it just locks up when I try.
The 2.5" nipple I used would be the bare minimum in length that would allow the handle to clear the tank bottom. A 4" would be better but @$13 I went with the $5.29 one.
   / Free air? #76
Gary, the galvanized el that I used is male on the end that screwed into the bottom of the tank, then female on the other end. The nipple is male on both ends, and of course the valve is brass. I don't guess I'd actually have to have the wheels on blocks, but if not, the female end of the el would be solid against the floor, as would the female end of the valve.
   / Free air? #77
That should be similar to mine then, but the brass fitting is really short radius of not more than 1/2" for take out. Maybe your tank sets much lower than mine.
Any idea on why I am no longer able to load photos?
   / Free air? #78
I'm afraid I can't help with the photo posting. I'm still having trouble with it myself with this Windows 8.1 and Charter cable.
   / Free air? #79
??? The forum pic uploading still works the same..
   / Free air? #80
Yeah, but when you get as old and forgetful as I am, and when you upload photos so seldom, you may forget how from one time to the next.:laughing:
2007 Ford Ranger Pickup Truck (A55788)
2007 Ford Ranger...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
Roll off Dumpster (A47477)
Roll off Dumpster...
Ingersol Rand 175 CFM Air Compressor (A53316)
Ingersol Rand 175...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
