Found problem intermittent starting on 4520.
/ Found problem intermittent starting on 4520. #1
Cidertom
Benton Co Oregon
JD 4520, 2305 Aktive snow-trac ST4
Problem: Intermittent starting issue 4520
Symptoms: Key on, fuel solenoid pulls in. on move key to "start" Gages cycle and the tach gage starts "ticking" one a second increasing reading each time. No starter function.
Tests: Battery above 12 Volts holds voltage during attempt to start. Battery posts clean and tight Ground cable attachment sound. Voltage at starter terminal 6 volts.
Troubleshooting: Using a needle probe through insulation on battery cable , found 6 volts 1/2 inch from positive battery terminal.
Replaced end on cable and no more problem.
Examination of faulted part: The factory potted end looked good, but on cutting it open it had corrosion inside and was not making good connections. Many of the copper wires had deteriorated to nothing.
/ Found problem intermittent starting on 4520. #2
Thanks for posting your end results.
/ Found problem intermittent starting on 4520. #3
Poor connections on battery terminals, spade lug terminals, and mate-n-lock (in line) connectors and other styles of connectors have caused MANY intermittent issues over the years for a lot of people, and some never get totally figured out. Some of them can be very hard to debug or diagnose, though.
/ Found problem intermittent starting on 4520. #4
Nasty, nasty problem. Congrats on figuring out rare type of failure.
Spartan SRT-XD Zero Turn Mower (A66285)
Spartan SRT-XD...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
1973 FRUEHAUF 26' ALUMINUM DUMP TRAILER (A64276)
1973 FRUEHAUF 26'...
Informational Lot - Shipping (A63689)
Informational Lot...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
