Found problem intermittent starting on 4520.
/ Found problem intermittent starting on 4520. #1
Cidertom
Benton Co Oregon
JD 4520, 2305 Aktive snow-trac ST4
Problem: Intermittent starting issue 4520
Symptoms: Key on, fuel solenoid pulls in. on move key to "start" Gages cycle and the tach gage starts "ticking" one a second increasing reading each time. No starter function.
Tests: Battery above 12 Volts holds voltage during attempt to start. Battery posts clean and tight Ground cable attachment sound. Voltage at starter terminal 6 volts.
Troubleshooting: Using a needle probe through insulation on battery cable , found 6 volts 1/2 inch from positive battery terminal.
Replaced end on cable and no more problem.
Examination of faulted part: The factory potted end looked good, but on cutting it open it had corrosion inside and was not making good connections. Many of the copper wires had deteriorated to nothing.
/ Found problem intermittent starting on 4520. #2
Thanks for posting your end results.
/ Found problem intermittent starting on 4520. #3
Poor connections on battery terminals, spade lug terminals, and mate-n-lock (in line) connectors and other styles of connectors have caused MANY intermittent issues over the years for a lot of people, and some never get totally figured out. Some of them can be very hard to debug or diagnose, though.
/ Found problem intermittent starting on 4520. #4
Nasty, nasty problem. Congrats on figuring out rare type of failure.
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A69167)
2016 INTERNATIONAL...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
Yamaha EF1000iS Portable Inverter Generator (A66734)
Yamaha EF1000iS...
2005 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A66736)
2005 Mack CH613...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2016 Ford Escape SUV. (A66738)
2016 Ford Escape...
