Foton 254 lost Drive
/ Foton 254 lost Drive #1
Rich07
Ottawa on
Foton 254
Hi Guys. All was going well, I doing some bush hogging, had been running around an hour when all of a sudden I stopped. I thought I was caught up on something so put the tractor into reverse but it won't go backwards either. I lifted the bush hog and tried again and still nothing. The engine runs good and the wheel can turn side to side. There is just no forward or backwards propulsion.
/ Foton 254 lost Drive #2
Is that a gear or shuttle shift. If it is a shuttle check your range lever ( high, low). Check to make sure the range selector is in the right spot. It can get bumped out and it will not move. This is what it sounds like.
Thanks I hadn't thought of that, I was hogging through some dense stuff at the time. I will give a try in the morning. Thanks again
Thanks again, seems like it jumped out of low range
/ Foton 254 lost Drive #5
No problem. I had a similar incident with my tractor. Took me about 5 minutes to figure out why it wouldn't move. Glad it was a simple fix.
