Foton 254 lost Drive
/ Foton 254 lost Drive #1
Rich07
Ottawa on
Foton 254
Hi Guys. All was going well, I doing some bush hogging, had been running around an hour when all of a sudden I stopped. I thought I was caught up on something so put the tractor into reverse but it won't go backwards either. I lifted the bush hog and tried again and still nothing. The engine runs good and the wheel can turn side to side. There is just no forward or backwards propulsion.
/ Foton 254 lost Drive #2
Is that a gear or shuttle shift. If it is a shuttle check your range lever ( high, low). Check to make sure the range selector is in the right spot. It can get bumped out and it will not move. This is what it sounds like.
Thanks I hadn't thought of that, I was hogging through some dense stuff at the time. I will give a try in the morning. Thanks again
Thanks again, seems like it jumped out of low range
/ Foton 254 lost Drive #5
No problem. I had a similar incident with my tractor. Took me about 5 minutes to figure out why it wouldn't move. Glad it was a simple fix.
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
Pipe Rack 5'9"Wx16'Lx6'6"H (A62679)
Pipe Rack...
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
2018 CATERPILLAR 299D2 SKID STEER (A65053)
2018 CATERPILLAR...
213090 (A64276)
213090 (A64276)
