Forum Upgrade - Any Issues?
/ Forum Upgrade - Any Issues? #661
There still seems to be many problems and quirks. :( My question is this. Is there someone trying to get things straightened out on their own, or do only the things that get reported get looked at and hopefully taken care of? :confused3:
My biggest complaint is when composing there are times when this happens. times when this happens. When you make a little bit longer post, this becomes this becomes very annoying. The summited post does not have the double wording, just in the composing section. What I find odd is that it doesn't always happen, more like it has a mind of it's own. Are you guys just messing with us? :rolleyes: ;)
Another bothersome thing is the smilies. I like them and all, but why when composing do they sometimes come up as code and other times as the actual figure? :confused:
Anyway, I get by, but was just wondering. :confused2:
/ Forum Upgrade - Any Issues? #662
Yea there working on them, they have a team doing it. Things change from week to week if you pay attenetion. The fixed the icons on the threads for example.
/ Forum Upgrade - Any Issues? #664
I was looking at Eddie Walker's thread re machu Pichu.....I was clearly looking at results 41 to 70, page 1, but it said I was looking at results 1 to 40...
copied below from that page...
Page 1 of 2 12 Next LastLast
Results 1 to 40 of 70
similar observation, this page...says I'm looking at results 1 to 40 yet am seeing results in the 600's
/ Forum Upgrade - Any Issues? #665
Where are you seeing that? When you hover your mouse over the page your on? Mine is showing like posts through 660 here?
/ Forum Upgrade - Any Issues? #666
At top of this thread page, it says "results 1 to 40" ...and shows several pages which are hyperlinks...and show that I'm on page 1of 17 ... and this page shows posts 665 thru 626
Point is I would anticipate it would say "results 665 to 626"
am using Firefox.
/ Forum Upgrade - Any Issues? #667
At top of this thread page, it says "results 1 to 40" ...and shows several pages which are hyperlinks...and show that I'm on page 1 ... and this page shows posts 665 thru 626
am using Firefox.
Are you sure you're not confusing pages with posts? The numbered links at the top and bottom of threads are pages, and the numbered links to the right of each post are posts. For example: This reply is post #667 on page #67 of this thread.
/ Forum Upgrade - Any Issues? #668
He is talking about the section at the top-right corner of the "post area" as seen in the screenshot below:
Aaron Z
/ Forum Upgrade - Any Issues? #669
I know, and never had any problem understanding it myself because nearly all forums use a similar format, so I wanted to make sure he wasn't confusing pages with posts. Granted, I failed to mention the "results" portion in my reply, but it's obvious (to me anyway) that it's referring to posts.
/ Forum Upgrade - Any Issues? #670
your screen shot is accurate regarding the area I'm discussing.
However, in my case, it shows results (posts) 1 to 40 while the posts on the page are actually in the 600's....thus, it differs from the screen shot in that way. I consider the screen shot to be accurate. I consider what I see to be inaccurate (but certainly not a earth shattering issue)
I actually understand what it is talking about and am able to ignore the incorrect information and have been doing so for some time...just thought I'd mention it.
/ Forum Upgrade - Any Issues? #671
That's odd because I'm also using Firefox, but on my computer the results are accurate. In this case it says "Results 661 to 670 of 670" as I'm typing this reply. Have you tried clearing your cache?
/ Forum Upgrade - Any Issues? #672
Any chance you could take a screenshot? What operating system and browser are you using?
Aaron Z
/ Forum Upgrade - Any Issues? #673
Here is the second copy/paste I've done
Page 1 of 17 123411 ... Next LastLast
Results 1 to 40 of 672
Page 1 is highlighted...that is where I am.... note that this page has the most recent posts...not results/posts 1 to 40.
if a screen shot is desired, how would you do that?? All that would do is provide a pretty picture of the copy/paste info.
using Firefox 14.0.1, the latest
Belarc Adviser says: Windows Vista Home Premium (x64) Service Pack 2 (build 6002)
Install Language: English (United States)
System Locale: English (United States)
/ Forum Upgrade - Any Issues? #674
Press the ALT and PRT SC keys at the same time, then open paint and press the CTRL key and the V key at the same time to paste the screenshot into paint and save the screenshot to upload to TBN. Note that the PRT SC key may be slightly different on your computer, but it's usually located on the upper right hand side of the keyboard, to the right of the function keys.
/ Forum Upgrade - Any Issues? #676
must be a firefox thing?
I would be surprised if it was, I am running Firefox 14 at work (with AdBlockPlus and NoScript) and 15 Beta (with AdBlockPlus) at home. Works fine for me at both places. My first guess would be a addon causing funkiness or some stuck piece of data in your cache.
Aaron Z
/ Forum Upgrade - Any Issues? #677
John Deere Owning Operating Forum Homepage never got fixed
/ Forum Upgrade - Any Issues? #679
Thanks,Muhammad!
I look at that forum often, it was like a popcorn shell stuck in my throat!:):thumbsup:
/ Forum Upgrade - Any Issues? #680
The Search doesn't work right. In example I type in "solar panel" expecting post containing word solar or panel or preferably only contaning phrase solar panel but I get irrelevant posts. Or I type in name of a member that has lot of posts and get response that nothing was found.
