Ford 8n 12v Coil Question
   / Ford 8n 12v Coil Question #1
DB1200
David Brown 1200
I have a 8n that is having some issues. It has been converted to 12v many years ago by the previous owner. The coil was suspect so I ordered a new one. The one that I ordered said it was internally resisted. So my question is do I still need to run the resistor block or do I need to wire it straight since the coil says it's internaly resisted. Thanks
   / Ford 8n 12v Coil Question #2
No need for two resistors
   / Ford 8n 12v Coil Question #3
Converted my 8N to 12 volt about 30 years ago, at first I didn’t install a resistor and pretty quickly ruined a set of points, had to install resistor and new points then everything was fine.
A few years ago the 70 year old original coil went bad so I bought new aftermarket coil, installed new coil and left the resistor in the line.
It’s been working perfectly in fact it starts better now than it ever did in all the years I’ve operated it.
My 8N has a front mount distributor maybe yours has a side mount distributor ?
   / Ford 8n 12v Coil Question #4
If it is a side mount and the coil is labeled as internally resisted then do away with the other resistors, if it is a front mount KEEP the resistor. I guessing you have a side mount since I have never heard of a front mount internally resisted front coil.
Yes it is the side mount and not the front mount.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
3 Point 5 1/2ft Metal Screen Cargo Carry (A51573)
3 Point 5 1/2ft...
Unused Delta Crash...
