Ford 841 Carb Help Needed
   / Ford 841 Carb Help Needed #1
Dennis 7
Calgary, Alberta
1959 Ford 841
I've ordered a parts kit from a dealer, but need step by step instructions for rebuilding the carb on my 1959 Ford 841.
Any help will be greatly appreciated!
-Dennis 7
   / Ford 841 Carb Help Needed #2
Well, a couple of things come to mind,
Ford New Holland 841 (G, LP, Dsl) Repair Manual Specialists RepairManual.com - Call 800-426-4214
or, you could ask your question on the New Holland forums.
When you ordered your parts did you by any chance happen to ask in the service department if the had a service manual for your tractor (either hard copy or online) that they could copy the relevent pages for you? Really, all you really need is the float setting, mixture screws can start out 1 turn from full bottom, and adjusted from there.
Ken
   / Ford 841 Carb Help Needed #3
Welcome to TBN :)
I moved your thread to the Ford Vintage Tractors Forum.
   / Ford 841 Carb Help Needed #4
did your carb kit not come with a lil half sheet of paper folde dup as a diagram?
in any case..i'd reccomend seperatingthe halves, removing air horn and float, especially if plastic.. then give a soak in a cleaner / dip pan.. then pull out.. blow out all passageways with air, and clean the rest with fine wire. guitar hi-e string works great if you know somebody that plays.
depending on the level of your kit, it may or may not come with new needles.
usually comes with throttle shaft seals, and choke packing.. etc..
if you remve any seats to repalce.. i'd reccomend a hollow ground screwdriver vs a spade tip.. though usually a spade tip will work...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
SHOULE RM8080 LOT NUMBER 129 (A53084)
SHOULE RM8080 LOT...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
