Ford 800
   / Ford 800 #1
ford tractor nut
St. Paris, Ohio
Ford 800
I have a Ford 800, and there is hydraulic oil coming from the streering box around the right side or front side where the lines screw in. Where could it be coming form any ideas?:confused:
   / Ford 800 #2
Does it have power steering?
   / Ford 800
Yes has steering, matter of it has great steering. Could a plugged power steering filter cause my problem?
   / Ford 800 #4
I suppose a clogged filter may have caused the leak, and if so you'll have to replace the filter and address the leak itself which might be due to seal failure in the control valve. There are two seals, upper and lower. The metal hoses from the pump to the valve and the valve to the cylinders will also leak if they get loose.
   / Ford 800 #7
You can usually tell where the leak is coming from. How much is leaking and where exactly is it coming from?
2014 FREIGHTLINER CASCADIA(INOPERABLE) (A48992)
2014 FREIGHTLINER...
2000 Chevrolet Express Passenger Van (A48082)
2000 Chevrolet...
2008 Pitts LB35-38 Lowboy Trailer, New Deck, Ramps (A47371)
2008 Pitts LB35-38...
2007 INTERNATIONAL 4300 (A48992)
2007 INTERNATIONAL...
More info coming soon! (A46683)
More info coming...
Landhonor 40gal 2 Stage Air Compressor (A47371)
Landhonor 40gal 2...
