Ford 5900
/ Ford 5900 #1
Cowman11
Ford 5900 & 5610
Is an early build 5900 the same as a late 5000
/ Ford 5900 #2
they are similar. The 5000 was US, or UK built from '65-'75, the 5900 was Mexico built '85-'93
/ Ford 5900
I am looking for radiator & air filter assembly for my 5900 but dealer said they were no longer available so I wonder if 5000 parts would fit?
/ Ford 5900 #4
According to messicks website, it is avaliable, but the origional part was superceeded.
But man is that one expensive radiator:confused2: even the aftermarket one if you scroll down is $460
New Holland 5900 4 CYL AG TRACTOR MEXICO
If you are handy around a garage and can fabricate, you may be able to make the aftermarket one from a 5000 work. At least it is only $260
New Holland 5000-SERIES 4 CYL TRACTOR
But you may also try searching elsewhere online to see if there is any cheaper aftermarket ones avaliable. And you could also tor taking it to a radiator shop for repair, depending on what is wrong.
/ Ford 5900 #5
I forgot to say that in the links you need to click on cooling and related parts at the left of the screen, and then click on radiator and related parts:thumbsup:
/ Ford 5900 #6
depending on the year model of the 5900 is if u use the radiator off the late model 5000's or the early 6610 series
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2020 FREIGHTLINER...
2008 VOLVO VNL64T T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2008 VOLVO VNL64T...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
