Ford 5900
/ Ford 5900 #1
Cowman11
Ford 5900 & 5610
Is an early build 5900 the same as a late 5000
/ Ford 5900 #2
they are similar. The 5000 was US, or UK built from '65-'75, the 5900 was Mexico built '85-'93
/ Ford 5900
I am looking for radiator & air filter assembly for my 5900 but dealer said they were no longer available so I wonder if 5000 parts would fit?
/ Ford 5900 #4
According to messicks website, it is avaliable, but the origional part was superceeded.
But man is that one expensive radiator:confused2: even the aftermarket one if you scroll down is $460
New Holland 5900 4 CYL AG TRACTOR MEXICO
If you are handy around a garage and can fabricate, you may be able to make the aftermarket one from a 5000 work. At least it is only $260
New Holland 5000-SERIES 4 CYL TRACTOR
But you may also try searching elsewhere online to see if there is any cheaper aftermarket ones avaliable. And you could also tor taking it to a radiator shop for repair, depending on what is wrong.
/ Ford 5900 #5
I forgot to say that in the links you need to click on cooling and related parts at the left of the screen, and then click on radiator and related parts:thumbsup:
/ Ford 5900 #6
depending on the year model of the 5900 is if u use the radiator off the late model 5000's or the early 6610 series
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
GMC 2500HD 4wd Service Truck (A61306)
GMC 2500HD 4wd...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
