Ford 4630
/ Ford 4630 #1
blws
Hornbeak Tn
4630 ford
My ford 4630 will not get fuel to feeder screw. squirts out a small bit occasionally. cranks off starting fluid. was wroking ok untill i changed fuel filter.
/ Ford 4630 #2
Make sure your fuel tank is 1/2 full or better. Even though it will run all the way to empty, bleeding the system requires at least half a tank on the 2-4000 series Fords.
/ Ford 4630 #4
You couldn't possibly have gotten the top seal ring in the wrong place on the top of the filter instead in the outer groove of the top cover??? Which would block the fuel.
/ Ford 4630
No I got it where suppose to b. any other suggestions?
/ Ford 4630 #6
take the supply line off and see what you get for fuel. You did not by chance shut the fuel valve on the tank off? I have also seen on diesel trucks where the filter gets air locked, try loosening the filter and using the hand primer
/ Ford 4630 #8
If it is like my 2 4000's it doesn't have a primer. I had one fuel line get plugged up before the filters - blew it back with an air compressor - probably blew the screen off in the tank - don't know, don't care - it has run fine for 2 years since. I have also wiped the filler off and blown into the tank until fuel went through the filters. That probably isn't the right thing to do either but it worked.
/ Ford 4630 #9
Just read the other thread. I would do every thing rick said to do - if that doesn't work ask rick for more ideas.
/ Ford 4630 #10
the 5610 series had a pushbutton primer by the fuelfilter, and putting air in the tank to blow through the filters does not hurt anything, have done it many times
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2020 Kenworth T680 Sleeper (A62613)
2020 Kenworth T680...
2020 Kawasaki Mule Pro DXT (A62613)
2020 Kawasaki Mule...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2023 Case 75c FarmAll Tractor (A62679)
2023 Case 75c...
