ford 4610
   / ford 4610 #1
tractorboy3011
Hi my ford 4610 has trouble starting off in gears higher than low one i adjusted the biting point on the clutch but it didnt do anything any ideas?
   / ford 4610 #2
Can you be more specific with describing your problem? Does the engine die, does the tractor shudder..... I flunked Mind Reading 101-ask my wife!
   / ford 4610
Well the engine stays running but goin on flat ground it takes a lot of revs to get rolling as if the handbrake was on(but i know its not stuck on)
   / ford 4610 #4
What rpm are you starting out with? Is the clutch slipping? Do you smell anything like a burned clutch? Any sign of oil dripping from the bell housing? How do you know the brakes are not stuck?
   / ford 4610
Idleing rpm but to get moving needs high rpm.no smell or oil.i know the brakes arent stuck on as it acts normal in lowest gear.
   / ford 4610 #6
What are you talking about regarding "...high rpm to get moving..."? Idle is about 700-800 rpm So what does it take to get you moving? max rpm is ~ 2200rpm so you have between say 800 to 2200 rmp working range.
   / ford 4610 #7
What transmission do you have? Shuttle or standard 8x2? Sent from my iPhone using TractorByNet
   / ford 4610
Standard but its 4 gears a range(hi,lo,reverse)
   / ford 4610 #9
8 forward and 2 reverse total correct? Also do all gears other than 1st slip or is it just certain gears?
   / ford 4610
8 forward four reverse and it only starts moving right in lowest gear.could it be the clutch?
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
20306 (A51694)
20306 (A51694)
2021 INTERNATIONAL LT625 (A52472)
2021 INTERNATIONAL...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
