FORD 445 ISSUES
/ FORD 445 ISSUES #1
STAMPEDE1
ALSIP, ILLINOIS
FORD 445
We have a Ford 445 tractor that will not start without a shot of ether. Once started it runs for about 15 minutes then dies. Any ideas?
This is with the PTO engaged with a tiller attachment. It almost seems as it is over heating but we're not sure.
/ FORD 445 ISSUES #2
Address your problems one at a time. They may not be related. Starting - does the exhaust show any smoke while cranking? Do you have a manifold heater and does it work? Is it turning over fast enough to start? How long has the problem existed? Did the starting problem and the engine stoppage come on together, or is one a newer condition? When the engine dies, what has to happen before it will restart? Just take some time passing or do you have to bleed any part of the system?
The starting issue could be low compression, weak injection pump delivery, or both. The stopping problem could be lack of supply(if you have to bleed it) or blocked return passage to fuel tank(if it starts right back up after five or ten minutes
Sakai SV505 (A60462)
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
