FORD 445 ISSUES
/ FORD 445 ISSUES #1
STAMPEDE1
ALSIP, ILLINOIS
FORD 445
We have a Ford 445 tractor that will not start without a shot of ether. Once started it runs for about 15 minutes then dies. Any ideas?
This is with the PTO engaged with a tiller attachment. It almost seems as it is over heating but we're not sure.
/ FORD 445 ISSUES #2
Address your problems one at a time. They may not be related. Starting - does the exhaust show any smoke while cranking? Do you have a manifold heater and does it work? Is it turning over fast enough to start? How long has the problem existed? Did the starting problem and the engine stoppage come on together, or is one a newer condition? When the engine dies, what has to happen before it will restart? Just take some time passing or do you have to bleed any part of the system?
The starting issue could be low compression, weak injection pump delivery, or both. The stopping problem could be lack of supply(if you have to bleed it) or blocked return passage to fuel tank(if it starts right back up after five or ten minutes
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2015 Nissan Sentra Sedan (A61574)
2015 Nissan Sentra...
Caterpillar Engine Parts and Service Manuals (A63117)
Caterpillar Engine...
2017 INTERNATIONAL PROSTAR + 122 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 INTERNATIONAL...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
