Ford 4000 spindle replacement
/ Ford 4000 spindle replacement #1
marlin1945
Idaho
Ford 4000 front loader/ Allis Chalmers / Minneapolis Moline/ D4 cat/ TD9/ Hough loader(1936)
Anyone have info on replacing front spindle unable to locate a match dimension -A = 10.625 ,D= 1.375 all others found have a dimension D= 1.250
/ Ford 4000 spindle replacement #2
I don't know exactly what the geometry looks like here but you may be able to find larger bearings that will fit the ID of your existing hub and the 1.25 OD of the spindle that you can find.
Ended up using the one that fit the larger bearing. ( Industrial spindle)The vertical shaft was longer. I had to weld the control arm to it as keyway on opposite side of longer shaft and had nothing for a spacer . Think the one I replaced was a modified original. At least everything is we working well. Also glad I have a timken reference book
/ Ford 4000 spindle replacement #4
A picture would have helped or be interested to see what you have. 3 cylinder or 4 cylinder 4000?
/ Ford 4000 spindle replacement #5
Yeah, there's at least 3 front axle setups on the 4000 tractors... one's like the 3000's, one bigger with shorter spindles, then the high crop setup with tall spindles like a 5000 or bigger...
Will do a bit later
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
2005 LUFKIN 45'X102" FLATBED TRAILER (A67714)
2005 LUFKIN...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2201SFL (A64553)
2201SFL (A64553)
