Ford 4000 spindle replacement
/ Ford 4000 spindle replacement #1
marlin1945
Idaho
Ford 4000 front loader/ Allis Chalmers / Minneapolis Moline/ D4 cat/ TD9/ Hough loader(1936)
Anyone have info on replacing front spindle unable to locate a match dimension -A = 10.625 ,D= 1.375 all others found have a dimension D= 1.250
/ Ford 4000 spindle replacement #2
I don't know exactly what the geometry looks like here but you may be able to find larger bearings that will fit the ID of your existing hub and the 1.25 OD of the spindle that you can find.
Ended up using the one that fit the larger bearing. ( Industrial spindle)The vertical shaft was longer. I had to weld the control arm to it as keyway on opposite side of longer shaft and had nothing for a spacer . Think the one I replaced was a modified original. At least everything is we working well. Also glad I have a timken reference book
/ Ford 4000 spindle replacement #4
A picture would have helped or be interested to see what you have. 3 cylinder or 4 cylinder 4000?
/ Ford 4000 spindle replacement #5
Yeah, there's at least 3 front axle setups on the 4000 tractors... one's like the 3000's, one bigger with shorter spindles, then the high crop setup with tall spindles like a 5000 or bigger...
Will do a bit later
PORTA POTTY (A68842)
2022 INTERNATIONAL LT625 DAYCAB (A67714)
2022 INTERNATIONAL...
2009 WESTERN STAR 4900 SF WINCH TRUCK (A67714)
2009 WESTERN STAR...
2000 FREIGHTLINER CENTURY CLASS DUMP TRUCK (INOPERABLE) (A67714)
2000 FREIGHTLINER...
2003 CHEVROLET EXPRESS 3500 PASSENGER VAN (A66091)
2003 CHEVROLET...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
