Ford 3910, what motor oil?
   / Ford 3910, what motor oil? #1
QRTRHRS
Elite Member
Liberty, Kentucky
None at this time.
I am working on my elderly neighbor's 3910. Her family is spread out all over the country so when they come home, there is little time for using the tractor, much less using it. Anyway, I am thinking 15-40 same as any diesel. Wouild that be a good choice or what would the resident Ford folks recommend?
Thanks in advance.
   / Ford 3910, what motor oil? #2
10W-30 is what's recommended for my climate-temperature range. I am about 60 miles north of Paducah, KY and normal temps range from 5-100* F
Per the book:
10W for -13-40
10W-30 for 0-100
15W-40 for 10-100
20W-40 or 20W50 for 20-100
SAE30 for 40-100
   / Ford 3910, what motor oil? #3
Thanks in advance.
15-40 should be fine unless the tractor has lots of hours and some engine wear, then straight 30 works well. Ken Sweet
Per the book:
10W for -13-40
10W-30 for 0-100
15W-40 for 10-100
SAE30 for 40-100
The tractor gets used mostly in the spring and fall but never in the winter when it unfortunately just sits. The farmer whom leases the land takes care of any snow.
   / Ford 3910, what motor oil? #7
If it were my tractor I'd be using 0-40 full synthetic. That's what goes in everything I own that goes up and down round and round.
It only has 1,240 hours on the clock which does work. For a machine with low hours that only gets occasional use, I think synthetic would be a better choice as well. However, I am not around that much to oversee what might get added if it should need some.
My neighbor is about 90 and she was not sure what was in it. One of her daughters comes more than the others. I may just hold off and ask her if she knows.
2012 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN2CH076971 (A51572)
2012 International...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
2018 Mazda CX-5 SUV (A51694)
2018 Mazda CX-5...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2006 John Deere 4120 Tractor (A51573)
2006 John Deere...
