Ford 3910, what motor oil?
   / Ford 3910, what motor oil? #1
QRTRHRS
Elite Member
Liberty, Kentucky
None at this time.
I am working on my elderly neighbor's 3910. Her family is spread out all over the country so when they come home, there is little time for using the tractor, much less using it. Anyway, I am thinking 15-40 same as any diesel. Wouild that be a good choice or what would the resident Ford folks recommend?
Thanks in advance.
   / Ford 3910, what motor oil? #2
10W-30 is what's recommended for my climate-temperature range. I am about 60 miles north of Paducah, KY and normal temps range from 5-100* F
Per the book:
10W for -13-40
10W-30 for 0-100
15W-40 for 10-100
20W-40 or 20W50 for 20-100
SAE30 for 40-100
   / Ford 3910, what motor oil? #3
Thanks in advance.
15-40 should be fine unless the tractor has lots of hours and some engine wear, then straight 30 works well. Ken Sweet
Per the book:
10W for -13-40
10W-30 for 0-100
15W-40 for 10-100
SAE30 for 40-100
The tractor gets used mostly in the spring and fall but never in the winter when it unfortunately just sits. The farmer whom leases the land takes care of any snow.
   / Ford 3910, what motor oil? #7
If it were my tractor I'd be using 0-40 full synthetic. That's what goes in everything I own that goes up and down round and round.
It only has 1,240 hours on the clock which does work. For a machine with low hours that only gets occasional use, I think synthetic would be a better choice as well. However, I am not around that much to oversee what might get added if it should need some.
My neighbor is about 90 and she was not sure what was in it. One of her daughters comes more than the others. I may just hold off and ask her if she knows.
2022 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A51219)
2022 FREIGHTLINER...
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
2016 John Deere 410E 40 Ton Articulated Off-Road Dump Truck (A50322)
2016 John Deere...
2008 VOLVO VNL670 SLEEPER (A51219)
2008 VOLVO VNL670...
CATERPILLAR 320FL EXCAVATOR (A51242)
CATERPILLAR 320FL...
