Ford 3910, what motor oil?
   / Ford 3910, what motor oil? #1
QRTRHRS
Elite Member
Liberty, Kentucky
None at this time.
I am working on my elderly neighbor's 3910. Her family is spread out all over the country so when they come home, there is little time for using the tractor, much less using it. Anyway, I am thinking 15-40 same as any diesel. Wouild that be a good choice or what would the resident Ford folks recommend?
Thanks in advance.
   / Ford 3910, what motor oil? #2
10W-30 is what's recommended for my climate-temperature range. I am about 60 miles north of Paducah, KY and normal temps range from 5-100* F
Per the book:
10W for -13-40
10W-30 for 0-100
15W-40 for 10-100
20W-40 or 20W50 for 20-100
SAE30 for 40-100
   / Ford 3910, what motor oil? #3
Thanks in advance.
15-40 should be fine unless the tractor has lots of hours and some engine wear, then straight 30 works well. Ken Sweet
Per the book:
10W for -13-40
10W-30 for 0-100
15W-40 for 10-100
SAE30 for 40-100
The tractor gets used mostly in the spring and fall but never in the winter when it unfortunately just sits. The farmer whom leases the land takes care of any snow.
   / Ford 3910, what motor oil? #7
If it were my tractor I'd be using 0-40 full synthetic. That's what goes in everything I own that goes up and down round and round.
It only has 1,240 hours on the clock which does work. For a machine with low hours that only gets occasional use, I think synthetic would be a better choice as well. However, I am not around that much to oversee what might get added if it should need some.
My neighbor is about 90 and she was not sure what was in it. One of her daughters comes more than the others. I may just hold off and ask her if she knows.
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
2004 FREIGHTLINER COLUMBIA 112 MID-ROOF SLEEPER (A50854)
2004 FREIGHTLINER...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
Unused 2025 CFG QK20R Mini Excavator (A49461)
Unused 2025 CFG...
2013 Ford F-250 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2018 TRAILSTAR END DUMP TRAILER (A50854)
2018 TRAILSTAR END...
