3-Point Hitch Ford 3400 3 point problem
   / Ford 3400 3 point problem #1
snorulz
Hello,
I have a Ford 3400 and the 3 point hitch is acting up. The hitch will only go all the way up or all the way down, you can't get it to do anything in between even if you only move the lever just a little bit. What would cause this problem?
Thanks
   / Ford 3400 3 point problem #2
Does the tractor have a selector for either Position Control or Draft Control? It sounds like you may have inadvertently selected Draft Control. In draft control, the implement only raises slightly as the tractor senses a change in plowing depth. This is normally sensed by toplink compression. The hydraulic lift either raises the implement or drops it all the way as you indicated in your post.
If you have position control selected, you could have something broken or out of adjustment causing the 3PH to only respond as it would in draft control. I don't have specific knowledge of your tractor to give you any more advice than that.
It does have the option for draft control but i tried the lever in both spots and it seems to act the same.
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
New Holland WorkMaster 37 (A53317)
New Holland...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
202483 (A54757)
202483 (A54757)
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
