2017 Boomer 54D 3 point hitch stiff
   / 2017 Boomer 54D 3 point hitch stiff #1
Shadyrun42
New Holland Boomer 54D
The lever on my NH 54D that operates the 3 point hitch has gotten increasingly harder to move. Stiff as a board. No problem holding implements, just hard to move. Any thoughts?
Thanks in Advance
   / 2017 Boomer 54D 3 point hitch stiff #2
Lubricate the linkage under the fender with spray on grease. I use motorcycle chain lube on the linkages under the fenders on my Kubota's. Motorcycle chain lube goes on thin and becomes thicker as the propellant evaporates.
   / 2017 Boomer 54D 3 point hitch stiff #3
Follow the 3 pt lever all the way down, till the pivot point and either spray some lube and work it a little bit to see if it helps, or adjust the lever tension on the friction discs.
Sorry to sound ignorant, but do I need to take the cover off to get to it? I have a cab, and the 3 point and PTO controls have a cover on them
Thank you!
   / 2017 Boomer 54D 3 point hitch stiff #5
Thank you!
Check if you can access it from the rear of the tractor, so you don't have to take all the cover apart. Not familiar with that exact tractor.
   / 2017 Boomer 54D 3 point hitch stiff #6
You have a cover in the cab but no cover on the linkage underneath. The linkage will always be exposed under the cab or fender.
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
2016 Ford Escape SUV (A59231)
2016 Ford Escape...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
