2017 Boomer 54D 3 point hitch stiff
/ 2017 Boomer 54D 3 point hitch stiff #1
Shadyrun42
New Holland Boomer 54D
The lever on my NH 54D that operates the 3 point hitch has gotten increasingly harder to move. Stiff as a board. No problem holding implements, just hard to move. Any thoughts?
Thanks in Advance
/ 2017 Boomer 54D 3 point hitch stiff #2
Lubricate the linkage under the fender with spray on grease. I use motorcycle chain lube on the linkages under the fenders on my Kubota's. Motorcycle chain lube goes on thin and becomes thicker as the propellant evaporates.
/ 2017 Boomer 54D 3 point hitch stiff #3
Follow the 3 pt lever all the way down, till the pivot point and either spray some lube and work it a little bit to see if it helps, or adjust the lever tension on the friction discs.
Sorry to sound ignorant, but do I need to take the cover off to get to it? I have a cab, and the 3 point and PTO controls have a cover on them
Thank you!
/ 2017 Boomer 54D 3 point hitch stiff #5
Thank you!
Check if you can access it from the rear of the tractor, so you don't have to take all the cover apart. Not familiar with that exact tractor.
/ 2017 Boomer 54D 3 point hitch stiff #6
You have a cover in the cab but no cover on the linkage underneath. The linkage will always be exposed under the cab or fender.
Sellick S80 (A60462)
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A61307)
Bulk Lot of over...
2013 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2013 BIG TEX 20...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
