2017 Boomer 54D 3 point hitch stiff
/ 2017 Boomer 54D 3 point hitch stiff #1
Shadyrun42
New Holland Boomer 54D
The lever on my NH 54D that operates the 3 point hitch has gotten increasingly harder to move. Stiff as a board. No problem holding implements, just hard to move. Any thoughts?
Thanks in Advance
/ 2017 Boomer 54D 3 point hitch stiff #2
Lubricate the linkage under the fender with spray on grease. I use motorcycle chain lube on the linkages under the fenders on my Kubota's. Motorcycle chain lube goes on thin and becomes thicker as the propellant evaporates.
/ 2017 Boomer 54D 3 point hitch stiff #3
Follow the 3 pt lever all the way down, till the pivot point and either spray some lube and work it a little bit to see if it helps, or adjust the lever tension on the friction discs.
Sorry to sound ignorant, but do I need to take the cover off to get to it? I have a cab, and the 3 point and PTO controls have a cover on them
Thank you!
/ 2017 Boomer 54D 3 point hitch stiff #5
Thank you!
Check if you can access it from the rear of the tractor, so you don't have to take all the cover apart. Not familiar with that exact tractor.
/ 2017 Boomer 54D 3 point hitch stiff #6
You have a cover in the cab but no cover on the linkage underneath. The linkage will always be exposed under the cab or fender.
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR8EH765283 (A61165)
2014 International...
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A61165)
2011 Ford F-350...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
2017 John Deere 5090GN (A53317)
2017 John Deere...
John Deere 567 Megawide (A60462)
John Deere 567...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
