Oil & Fuel Ford 2810 pto problem
/ Ford 2810 pto problem #1
samgpat
Ford 2810
First time to try this .
I have a 2810 series II and the PTO will sometimes not engage immediately. Have to move the tractor to engage. Apparently hyd. engagement some way. Any ideas, also how do I check the fluid level don't see any stick or site glass, what lube should be in system?
Any advice appreciated.
/ Ford 2810 pto problem #2
What type pto ind or dual-stage clutch?? Type of hyd oil is 134 and if no dipstick should have a check plug about 1/2 way up on RH side of trans case.
Thanks I would cause it a indipendant pto -- runs with clutch engaged once I get the pto running.
PORTA POTTY (A68842)
2005 Acura RSX Coupe (A66738)
2005 Acura RSX...
2013 CHEVROLET CRUZE CAR (A66091)
2013 CHEVROLET...
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
LEEBOY 8515B PAVER (A67714)
LEEBOY 8515B PAVER...
