Oil & Fuel Ford 2810 pto problem
/ Ford 2810 pto problem #1
samgpat
Ford 2810
First time to try this .
I have a 2810 series II and the PTO will sometimes not engage immediately. Have to move the tractor to engage. Apparently hyd. engagement some way. Any ideas, also how do I check the fluid level don't see any stick or site glass, what lube should be in system?
Any advice appreciated.
/ Ford 2810 pto problem #2
What type pto ind or dual-stage clutch?? Type of hyd oil is 134 and if no dipstick should have a check plug about 1/2 way up on RH side of trans case.
Thanks I would cause it a indipendant pto -- runs with clutch engaged once I get the pto running.
2018 Holbart 210 MVP Mig Welder (A68183)
2018 Holbart 210...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
2023 JOHN DEERE 35P EXCAVATOR (A65056)
2023 JOHN DEERE...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
GENIE GTH-842 TELESCOPIC FORKLIFT (A65056)
GENIE GTH-842...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
