Ford 2600 Fluid change
/ Ford 2600 Fluid change #1
Jrusche
Ford 2600
Looking to change all the fluids in Ford 2600. I can not seem to find where all the drain plugs are. I have a IT Ford Shop manual but cant find where they explain where to change it. Im sure its something simple. Any help would be great.
/ Ford 2600 Fluid change #2
Did you get an answer?
Engine is straightforward. Transmission and rear end are pipe plugs underneath.
/ Ford 2600 Fluid change #3
If you don't find a pet-cock on the lower right or left side of the radiator, remove the lower radiator hose at the radiator to drain.
As mentioned , the tractor is probably a 2 section fluid compartment:
Under the engine's oil pan will be a plug.
Somewhere under the trans/hydraulic section/differential there will be from 1 to 3 plugs....check all 3 locations because different tractors vary in quantity and location.
On 4wd tractors, the engine usually has an inverted U shaped oil pan allowing for the front axle shaft to tranverse that distance so there are 2 drain plugs, one on each side of the drive line to the front axle.
