Ford 2000 3-cyl gasser losing power with any load on PTO-suggestions needed to fix
   / Ford 2000 3-cyl gasser losing power with any load on PTO-suggestions needed to fix #1
tmac196
Temperance, MI
1951 Ford 8N, 1965 Ford 2000, Grasshopper 325D, JD 5065M
1965 Ford 3 cyl gasser. Problem began a few weeks ago. Runs well with load on drawbar (soil conditioner), but with any load on the PTO (hay rake, hay tedder, bush hog (60 inch), I lose power and the engine begins to burble and run very rough. RPMs drop and if I don't depress the clutch to disengage the PTO the engine appears to be on it's way of shutting down. I can improve the problem minimally and briefly with a tad more choke and a tad more throttle, but rather quickly, in spite of these changes, the problem will recur.
To attempt to solve the problem, I emptied the fuel tank and examined it. Found a long ago metal spout from an old gas can and a broken fuel stopcock filter lying in the bottom of the tank (since removed), but a clean tank. The fuel stopcock was replaced with a new unit and now the tank has a functioning filter. Next, I pulled the cover off the fuel pump and found it completely plugged with debris. The pump filter and gasket were removed and replaced and the pump was cleaned out with suction and cranking the engine a few turns. At the time the fuel pump filter was replaced, the fuel was flowing freely and was clear (no debris) out of the top of the pump with cranking. The sediment bowl was examined and the fuel filter there was washed in clean gasoline and was not plugged with debris. Fuel ran freely from/ through it. As this was the next filter in line and was clean and free of debris, I did not attempt to assess the filter at the carburetor, access to which appears to be a major PIA based on the steel fuel line running between the block and the carb, access to whose fittings would be a big undertaking. Fuel flows freely from the carburetor bowl drain plug.
The engine was given a tune-up. New plugs (correct gap set), points (gap 0.025), rotor and condenser-all from a kit supplied by the local dealer. The distributor cap, a Motorcraft part, was only two years old, in excellent shape and was retained. Finally, I replaced the coil and wire between the coil and the center of the distributor cap as I broke the electrodes off the old wire as I was removing it from the distributor cap. Coil wires to the battery and distributor housing were in excellent shape.
After the tune up, the tractor fired right up and ran smoothly. Good throttle response and power range. I groomed about two acres of horse riding arenas with a soil conditioner and it ran well. As soon as I hooked up the bush hog and engaged the PTO to test the power, the problem recurred.
I am looking for suggestions as to how to solve this problem and where to look next.
   / Ford 2000 3-cyl gasser losing power with any load on PTO-suggestions needed to fix #2
Does it run ok with no load on the PTO? Are the govenor function so it keeps constant rpm under different load?
Are the PTO implement you use I working condition? Can it be a faulty gearbox on the brink to lock up?
Runs normally with no load on PTO.
PTO powered implements (3 so far) are in excellent condition with normal, healthy gearboxes. All three cause the problem to recur when used.
Governor? I can't say, really. The implement I pull with the drawbar is a soil conditioner. It's merely scratching the surface and smoothing a horse riding arena, so I can't tell you if I have perceived governor inadequacies. It is, I suppose, a possiblity.
   / Ford 2000 3-cyl gasser losing power with any load on PTO-suggestions needed to fix #4
When PTO is engaged, does it respond to throttle?
   / Ford 2000 3-cyl gasser losing power with any load on PTO-suggestions needed to fix #5
I'm thinking that, if the problem was with the governor, just advancing the throttle would take care of the problem. Since nothing the op does to the engine controls seems to help, I would look toward the pto itself. I'm not familiar with this particular model, but is there a brake on the pto when it is disengaged and could that be coming on at the wrong time? Or, is there a bad bearing in the pto?
   / Ford 2000 3-cyl gasser losing power with any load on PTO-suggestions needed to fix #6
Does the PTO tap spin easy?
PTO shaft spins easily and freely and quietly.
Update: Playing with the throttle in neutral reproduced my problems today. It runs rough as I boost the throttle and runs fine at idle. This is the first time I noticed the problem sitting still and the problem may be getting worse because of it.
What about a defective fuel pump? Short of replacing it, is there any way to definitively test the fuel pump function?
   / Ford 2000 3-cyl gasser losing power with any load on PTO-suggestions needed to fix #8
Vacuum and pressure gauge should give some useful info.
Ziehl-Abegg Fan (A47384)
Ziehl-Abegg Fan...
2017 Nissan Titan Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
Blue Diamond Quick Attach 6 Way Blade (A50514)
Blue Diamond Quick...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2025 Swict 60in Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
100 Safety Cones (A47384)
100 Safety Cones...
