Ford 1920 antifreeze leak at block fitting
   / Ford 1920 antifreeze leak at block fitting #11
Here is the socket I used.
   / Ford 1920 antifreeze leak at block fitting #12
WD40 is basically worthless as a penetrant. All it's really good for is water displacement. Blaster is much better and a mix of red ATF and acetone is even better and cheaper.
Awesome and thanks for the advice fellas. Will tackle this as soon as I can find a replacement fitting. Any help identifying what to look for and where? Ditto on the ATF. Been fixing up my old 96 tacoma the last 6 months and ATF certainly has helped on plenty of threads.
Well I guess I was searching the wrong terms. Found some more info for what appears to be a common problem. Sorry for all the questions folks and thanks again for the advice.
Perfect. Thank you!
   / Ford 1920 antifreeze leak at block fitting #18
I'm also a big fan of red atf 50:50 with acetone. I put it in one of these and use the compressor - never going back to liquid wrench or pb blaster
Tackled the fitting this afternoon. Cut the hose barb part off so I could get a socket on it with a long handle ratchet. ATF and acetone for a bit and it broke loose. Sort of creaked a few times then spun out clean. Took maybe 30-45 minutes total. Cleaned the area up a little, ran tractor for a while and found no leaks. Thank you for all the advice fellas.
20704 (A55853)
20704 (A55853)
2013 Ford E-350 Cargo Van (A56858)
2013 Ford E-350...
2016 GREAT DANE 53’ REEFER TRAILER (A58018)
2016 GREAT DANE...
DAVID BRADLEY W/ CULTIVATOR & AXLE W/ SPRINGS (A58374)
DAVID BRADLEY W/...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
