Ford 1920 antifreeze leak at block fitting
   / Ford 1920 antifreeze leak at block fitting #11
Here is the socket I used.
   / Ford 1920 antifreeze leak at block fitting #12
WD40 is basically worthless as a penetrant. All it's really good for is water displacement. Blaster is much better and a mix of red ATF and acetone is even better and cheaper.
Awesome and thanks for the advice fellas. Will tackle this as soon as I can find a replacement fitting. Any help identifying what to look for and where? Ditto on the ATF. Been fixing up my old 96 tacoma the last 6 months and ATF certainly has helped on plenty of threads.
Well I guess I was searching the wrong terms. Found some more info for what appears to be a common problem. Sorry for all the questions folks and thanks again for the advice.
Perfect. Thank you!
   / Ford 1920 antifreeze leak at block fitting #18
I'm also a big fan of red atf 50:50 with acetone. I put it in one of these and use the compressor - never going back to liquid wrench or pb blaster
Tackled the fitting this afternoon. Cut the hose barb part off so I could get a socket on it with a long handle ratchet. ATF and acetone for a bit and it broke loose. Sort of creaked a few times then spun out clean. Took maybe 30-45 minutes total. Cleaned the area up a little, ran tractor for a while and found no leaks. Thank you for all the advice fellas.
2013 Yamaha Golf Cart (A57453)
2013 Yamaha Golf...
2018 Nissan Pathfinder (A56859)
2018 Nissan...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2021 Kubota SVL75-2 Track Loader (A56436)
2021 Kubota...
