ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,469
- Location
- southern wisconsin
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
Here is the socket I used.
Perfect. Thank you!Well I guess I was searching the wrong terms. Found some more info for what appears to be a common problem. Sorry for all the questions folks and thanks again for the advice.
Engine Coolant Drain-Plug Leak
For all Ford and NH Tractor Owners with the infamous leaking block! I put up with it for years on my Ford 1720 and for almost 4 on my TC 40D. I tried several fixes, including new plugs, teflon tape, blue silicone sealant, pipe dope, etc, all to no avail. ...But, I think I've got it by-golly...www.tractorbynet.com
I'm also a big fan of red atf 50:50 with acetone. I put it in one of these and use the compressor - never going back to liquid wrench or pb blasterWD40 is basically worthless as a penetrant. All it's really good for is water displacement. Blaster is much better and a mix of red ATF and acetone is even better and cheaper.
