ford 1900 injector pump help
   / ford 1900 injector pump help #1
paulyny
Trying to get my father in laws ford 1900 running. Tractors been sitting at least 5 years. Change the fluids and fuel. Problem is injector pump. Only have fuel coming out of one of the injectors.I know this is probably an expensive repair but I did see a company online a few years ago that rebuilt these Kiki pumps. Any advice greatly appreciated.
   / ford 1900 injector pump help #2
I'll admit upfront I know as much about diesel injection systems as I do about the surface of the moon. Why, if your getting fuel to one injector do you suspect the pump? I'd start with the non performing injector(s).
   / ford 1900 injector pump help #3
Injection pumps won't pump air. Did you bleed the fuel system from tank to injectors? There's a sequence you need to follow.
   / ford 1900 injector pump help #4
1900's are hard to bleed like someone else said bleed from tank to pump first, then injectors.
Good luck
If I remember well, I referenced afford 1710 service manual. Im gonna give it another try.
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
1712 (A58375)
1712 (A58375)
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2021 Bobcat T66 Skid Steer (A57453)
2021 Bobcat T66...
