ford 1900 injector pump help
   / ford 1900 injector pump help #1
paulyny
Trying to get my father in laws ford 1900 running. Tractors been sitting at least 5 years. Change the fluids and fuel. Problem is injector pump. Only have fuel coming out of one of the injectors.I know this is probably an expensive repair but I did see a company online a few years ago that rebuilt these Kiki pumps. Any advice greatly appreciated.
   / ford 1900 injector pump help #2
I'll admit upfront I know as much about diesel injection systems as I do about the surface of the moon. Why, if your getting fuel to one injector do you suspect the pump? I'd start with the non performing injector(s).
   / ford 1900 injector pump help #3
Injection pumps won't pump air. Did you bleed the fuel system from tank to injectors? There's a sequence you need to follow.
   / ford 1900 injector pump help #4
1900's are hard to bleed like someone else said bleed from tank to pump first, then injectors.
Good luck
If I remember well, I referenced afford 1710 service manual. Im gonna give it another try.
SDLanch SDLGC80 Electric Golf Cart (A57149)
SDLanch SDLGC80...
Toyota Electric Walk Behind Pallet Jack (A57149)
Toyota Electric...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57453)
New/Unused AGT...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
UNUSED FUTURE MPR42 42" HYD MINI POWER RAKE (A58376)
UNUSED FUTURE...
