JC,
The tractor has never lost locomotion, the loader is in the way to see in the rubber plug, the one on the left is about 1/2 dollar size and also has the same size plug on the right. The gear that drives the orc countershaft is on the clutch side of the gears that drive the transmission, therefore it could not be on the inner shaft of a 2 stage clutch as you had said would be the case in an earlier post. The gears on the lower transmission shaft spin as one unit pushing on them with a prybar. My conclusion is that I have a single clutch. The powerflow also leads me to the same conclusion.
powerflow:
The power comes in from the clutch and drives the lower shaft in the transmission, this shaft has a gear that drives the countershaft that drives the orc and also has gears that drive the 3 speeds and reverse on the upper transmission shaft.
The upper shaft drives the range selecter.
The range selector drives the differential that drives the rear wheels.
I noticed some milky fluid draining from the orc which tells me that water has gotten in there. Before I reassemble this tractor I am going to rinse it all out with kerosene. I have decided this weekend I will drive the pto shaft, pto countershaft out the rear and remove the orc for inspection, this will also give me piece of mind that the outer race of the orc has the added bearings from the TSB. If I discover any play in the bearings I will replace them. this will also give me a chance to inspect all of these parts for corrosion due to the water I removed last fall. Before I removed the contaminated fluid I had ran the brush hog for about 20 hours last year.
Do you agree with me that this is the next logical step since I already have the tractor split so that these parts can be serviced?
P.S. The TSC Premium fluid meets Ford 134 d,c,b,a specs per the container. The manual says the tractor requires FNH 134 fluid.
