Ford 1710 stays on hot
   / Ford 1710 stays on hot #1
actedesco
1984 Ford 1710 and 700b loader
Hi, i have a ford 1710 that had a old temp gauge stuck on hot so I replaced the temp sensor and installed a new temp gauge that stays on hot as well right out of the box. I am new to this site and hope to find some help.
   / Ford 1710 stays on hot #2
Welcome to TBN. :)
   / Ford 1710 stays on hot #3
WELCOME to TBN :)
I moved your thread to the Ford Vintage Tractors Forum.
   / Ford 1710 stays on hot #4
electronic gauge?
mechanical gauge?
soundguy
Electric...2 post on back of gauge. One I assume is a power supply the other goes to the temp sensor. It also has a dedicate ground wire. When I take the wire off the temp sensor and touch it to a ground it does nothing. When I touch the wire to a positve source it moves the gauge.
   / Ford 1710 stays on hot #6
Have you tried pressure washing the radiator. Mine clogged with dirt after 20 years of use. I had the same symptoms on my 1310.
   / Ford 1710 stays on hot #7
I had a 1710, clean the radiator like mention above and if that doesn't do it a thermastat would be my next item.
I flushed the radiator really good but I didn't power wash it. Just used a regular spray nozzle on a hose. The tractor doesn't seem to be getting hot. Just makes me nervous not knowing whether or not the engine is getting to hot.
   / Ford 1710 stays on hot #9
Do you know anyone with a IR heat gun ? You could check the outer temp of the radiator or engine block. It should be less that the thermostat temp rating. A local garage might have one you can borrow or maybe Autozone if one is nearby.
   / Ford 1710 stays on hot #10
if the gage goes 'hot' as soon as he turns the key on it CERTAINTLY is not a dirty radiator guys!!!!
soundguy
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
