Ford 1710 stays on hot
   / Ford 1710 stays on hot #1
actedesco
1984 Ford 1710 and 700b loader
Hi, i have a ford 1710 that had a old temp gauge stuck on hot so I replaced the temp sensor and installed a new temp gauge that stays on hot as well right out of the box. I am new to this site and hope to find some help.
   / Ford 1710 stays on hot #2
Welcome to TBN. :)
   / Ford 1710 stays on hot #3
WELCOME to TBN :)
I moved your thread to the Ford Vintage Tractors Forum.
   / Ford 1710 stays on hot #4
electronic gauge?
mechanical gauge?
soundguy
Electric...2 post on back of gauge. One I assume is a power supply the other goes to the temp sensor. It also has a dedicate ground wire. When I take the wire off the temp sensor and touch it to a ground it does nothing. When I touch the wire to a positve source it moves the gauge.
   / Ford 1710 stays on hot #6
Have you tried pressure washing the radiator. Mine clogged with dirt after 20 years of use. I had the same symptoms on my 1310.
   / Ford 1710 stays on hot #7
I had a 1710, clean the radiator like mention above and if that doesn't do it a thermastat would be my next item.
I flushed the radiator really good but I didn't power wash it. Just used a regular spray nozzle on a hose. The tractor doesn't seem to be getting hot. Just makes me nervous not knowing whether or not the engine is getting to hot.
   / Ford 1710 stays on hot #9
Do you know anyone with a IR heat gun ? You could check the outer temp of the radiator or engine block. It should be less that the thermostat temp rating. A local garage might have one you can borrow or maybe Autozone if one is nearby.
   / Ford 1710 stays on hot #10
if the gage goes 'hot' as soon as he turns the key on it CERTAINTLY is not a dirty radiator guys!!!!
soundguy
2014 John Deere 630FD Draper Head (A53342)
2014 John Deere...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
377811 (A48836)
377811 (A48836)
