ford 1520 tractor, stuck in neutral (hydrostatic )
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #1
raykolvites
hillsborough, nj
ford 1520
I was just plowing a little snow, tractor working perfectly, all of a sudden it stopped moving. It will not go into forward or reverse. PTO, hydraulics working fine.
Any ideas what is wrong?
thanks Ray
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #2
FO-46 I&T shop manual says under troubleshooting paragraph 98:
1. Tractor will not move or operates erratically,
a. Engine clutch or transmission input shaft failure,
b. Transmission oil level low,
c. Charge pump or charge pressure relief valve defective,
d. Pump or motor cylinder block or valve plates defective,
e. Feed valve or neutral valve sticking open.
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #3
f. wire(s) pulled of HST forward and/or reverse solenoids.
thank you for getting back to me, I will check the items out
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
Caterpillar 60in Pallet Fork and Frame Attachment (A49461)
Caterpillar 60in...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
