ford 1520 tractor, stuck in neutral (hydrostatic )
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #1
raykolvites
hillsborough, nj
ford 1520
I was just plowing a little snow, tractor working perfectly, all of a sudden it stopped moving. It will not go into forward or reverse. PTO, hydraulics working fine.
Any ideas what is wrong?
thanks Ray
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #2
FO-46 I&T shop manual says under troubleshooting paragraph 98:
1. Tractor will not move or operates erratically,
a. Engine clutch or transmission input shaft failure,
b. Transmission oil level low,
c. Charge pump or charge pressure relief valve defective,
d. Pump or motor cylinder block or valve plates defective,
e. Feed valve or neutral valve sticking open.
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #3
f. wire(s) pulled of HST forward and/or reverse solenoids.
thank you for getting back to me, I will check the items out
1991 International 4900 Box Truck (A51039)
1991 International...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2023 QUALITY CARGO 16 T/A ENCLOSED TRAILER (A50854)
2023 QUALITY CARGO...
Miller Bobcat 225G Welder (A49461)
Miller Bobcat 225G...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2018 INTERNATIONAL...
