ford 1520 tractor, stuck in neutral (hydrostatic )
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #1
raykolvites
hillsborough, nj
ford 1520
I was just plowing a little snow, tractor working perfectly, all of a sudden it stopped moving. It will not go into forward or reverse. PTO, hydraulics working fine.
Any ideas what is wrong?
thanks Ray
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #2
FO-46 I&T shop manual says under troubleshooting paragraph 98:
1. Tractor will not move or operates erratically,
a. Engine clutch or transmission input shaft failure,
b. Transmission oil level low,
c. Charge pump or charge pressure relief valve defective,
d. Pump or motor cylinder block or valve plates defective,
e. Feed valve or neutral valve sticking open.
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #3
f. wire(s) pulled of HST forward and/or reverse solenoids.
thank you for getting back to me, I will check the items out
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
