ford 1520 tractor, stuck in neutral (hydrostatic )
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #1
raykolvites
hillsborough, nj
ford 1520
I was just plowing a little snow, tractor working perfectly, all of a sudden it stopped moving. It will not go into forward or reverse. PTO, hydraulics working fine.
Any ideas what is wrong?
thanks Ray
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #2
FO-46 I&T shop manual says under troubleshooting paragraph 98:
1. Tractor will not move or operates erratically,
a. Engine clutch or transmission input shaft failure,
b. Transmission oil level low,
c. Charge pump or charge pressure relief valve defective,
d. Pump or motor cylinder block or valve plates defective,
e. Feed valve or neutral valve sticking open.
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #3
f. wire(s) pulled of HST forward and/or reverse solenoids.
thank you for getting back to me, I will check the items out
2012 Chevrolet Traverse SUV (A50324)
2012 Chevrolet...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
