ford 1520 tractor, stuck in neutral (hydrostatic )
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #1
raykolvites
hillsborough, nj
ford 1520
I was just plowing a little snow, tractor working perfectly, all of a sudden it stopped moving. It will not go into forward or reverse. PTO, hydraulics working fine.
Any ideas what is wrong?
thanks Ray
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #2
FO-46 I&T shop manual says under troubleshooting paragraph 98:
1. Tractor will not move or operates erratically,
a. Engine clutch or transmission input shaft failure,
b. Transmission oil level low,
c. Charge pump or charge pressure relief valve defective,
d. Pump or motor cylinder block or valve plates defective,
e. Feed valve or neutral valve sticking open.
   / ford 1520 tractor, stuck in neutral (hydrostatic ) #3
f. wire(s) pulled of HST forward and/or reverse solenoids.
thank you for getting back to me, I will check the items out
Heavy-Duty Round Bale Trailer - Tandem Axle, High-Capacity Hay Hauler (A51039)
Heavy-Duty Round...
2020 KUBOTA RTV...
2017 Claas Jaguar 860 Forage Harvester (A51039)
2017 Claas Jaguar...
1995 CATERPILLAR 621E (A50854)
1995 CATERPILLAR...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2023 MAXXD TDX Drop-N-Load Trailer with Air Ride Suspension and Tilt Deck (A51039)
2023 MAXXD TDX...
