For Those Without a BH, How Do you Do It?
   / For Those Without a BH, How Do you Do It? #1
Kyle241
Platinum Member
Eastern Ontario
Kubota MX5100
Such tasks as boulder/stone removal, stump removing, etc.? I currently have a Kubota B20 and am looking to upgrade however a 40hp+ tractor with a BH is expensive so I was wondering whether I could survive without one. I do have a lot of stones on my property and I have a number of stumps I need to remove (4"-10" trees - elm, ash, birch). I am currently looking at a Kubota MX4700 or a Kioti DK45SE and would purchase a BB.
Other than renting a mini-ex, any other tips if I am sans BH?
Tks.
   / For Those Without a BH, How Do you Do It? #2
Nope, we just rent when needed. If we needed one on a regular basis we would buy one or fix up the one we have sitting in our shed.
I will be interested to see any ideas which may save us money.
   / For Those Without a BH, How Do you Do It? #4
Before I got my BH, I rented a stump grinder to remove stumps. I did 13 in one day I think. I could not have dug up 13 in one day for sure as big as these were. They were about 36" in dia and would have probably taken me 2-3 hours with the Woods BH-80x on my Bobcat.
I don't have many large rocks so I can't help you there. I did dig a few up with my bucket before I got the BH but that was very time consuming also.
   / For Those Without a BH, How Do you Do It? #5
"Sans Hoe"
OK, I'll pass on the obvious opportunities (-:
I think renting a mini-ex is your best alternative and may help you decide if you REALLY want to dig stumps (-:
The first few are "interesting" after that it becomes boring and/or frustrating, boring because some come out easily, frustrating because others don't (-:
Your current tractor doesn't have much weight to it, so tricks such as dragging a sub soiler across the roots to loosen them and then PULLING trees down instead of CUTTING them down may not be an option.
This works by getting the root ball out of the ground AS THE TREE FALLS (a twofer).
If you go to a 40+ HP tractor with a weight closer to 3 tons things change a bit, but the hoe is still an expensive option.
4,000 lb tractor + 1200 lb loader + 1000 lbs liquid ballast ~= 3 tons.
Figure another 1,000 to 1,200 for a hoe, but some other implements weigh close to that anyway, so JUST for weight on the ground to tug trees down you don't need to spend big bucks on a hoe.
There are stump buckets and stump grapples, just be sure your FEL frame can take actual DIGGING before committing to one of these, they are built for skid steers and although they clip right onto skid steer compatible loaders that doesn't necessarily mean that you can dig with your loader - depends what loader you get on whatever next machine you get.
If I was doing it all again (with 20/20 hindsight, etc.) I would probably hire out the tree removal and stump disposal - dozer & a decent sized ex, etc.
OTOH, if I really felt a NEED to SPEND on a hoe, it would almost certainly be a side shifting one.
   / For Those Without a BH, How Do you Do It? #6
x 2 on the stump grinder. I rented one for a half day and, for a couple of hundred bucks, took out about 10 stumps.
Pallet forks come in handy for moving rocks and can be used to pop smaller trees.
You are planning on get a fel also right?
Yes, definitely with a tooth bar as well.
I had not even thought of a stump grinder but that is a good idea. To Reg's point, digging up stumps is not always fun and some can really get frustrating. The grinder is a decent option as it wouldn't create the big holes that removing a stump does.
So now I just need to figure out what to do with the stones. Some are decent size, not just little nuggets. The forks some like a possibility but never had them so no experience.
Tks for the tips and I'll think long and hard about this because once you have a BH, it's hard to give one up.
   / For Those Without a BH, How Do you Do It? #8
I have dug up a lot of stumps with a FEL, but I wont lie and say it is super easy or anything, sometimes a big stump can take a half a day, and you got a big hole mess to fill and backdrag, but it can be done. It is best to pull trees over if your tractor is big enough, saves all that nasty stump digging. I have never used a stump grinder but it sounds great!
I have a semi-funny story, about stump grinders: I had cleaned out a fence row, of everything but about 6 large stumps, and on one particulary large one, I had put a "smile" in my old Long tractors bucket by pushing/lifting with too much traction by having the tractors rear wheels on pavement. So called it quits for the day, with the stumps intact. Went back at it the next weekend, drove to the fence-row and stared at it in disbelief, as all six of the stumps had disappeared. Left in their place, was just ground up wood chips. :confused2:
Apparently thru the week the "Stump Fairy" had come and ground up the stumps. I never learned who or what had done it, but I was grateful:thumbsup:
James K0UA
James K0UA
James, now that is funny. My guess is you have a very nice neighbour!!!
   / For Those Without a BH, How Do you Do It? #10
Tks.
I would consider the tractor size, do you need as big as you are looking at, maybe alittle smaller will make up for an added package deal for the BH.
Get it you will never regret it.
I am new to tractors and have only a small yard and I own a small tractor, a CCY-SC2450 - TLB.
I pruchased the SCUT first for snow remaval and then decided that a FEL would be nice, then thought on it and got the TLB and I am glad I did.
I am never in a rush to do anything so digging up two stumps in five to six hours is not a problem but being able to do and when I want to are the key things.
I have built a small stone wall that would have run me in the ground and remove the two stumps that may never have tackled but the tractor and BH never batted and eye lid while performing the tasks.
My point is if you can get a good deal on a Tractor with a BH/3 pt hitch and you can afford it then get it; it is better to have it and use it when you need to than not to have it.
This is IMHO and I for one never looked back at the extra money for the BH, it has paid for itself last summer and with the drainage ditch and the patio/firepit going this year, it will more than makeup for money spent.
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
Deere 333G (A53317)
Deere 333G (A53317)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
