For the future
/ For the future #1
pruntyc
Platinum Member
MS
John Deere 4110 HST
My 1700 of course doesn't have a water pump. And I know the 2000 has one. Where does it start at, anything below the 2000? I hope to have one someday that has a water pump. Mine doesn't get that hot all the time, but it does at times. So I think a water pump will have to be a must on my next one. You know like the potato chip, where you can't eat just one. Well, you can't have just one tractor, I think. My wife thinks one is enough though. /forums/images/graemlins/grin.gif
/ For the future #2
I'm not sure of this, but I believe all 3 cyl. engines and 2 cyl. above YM1700 have waterpumps. It also appears that a YM2000 waterpump will bolt up to a YM1700. Several guys have done that.
/ For the future #3
I just got a "water pump kit" from Fredricks this week. It is complete and very easy to install. The only changes I had to make were cutting two bolts off about 3/16" and adding a couple of washers. I am glad I went that way because there is more to it than just buying a pump and putting it on. There are different hoses and plates.
/ For the future #4
Yeah, I got one from Fredricks when I rebuilt the engine on my 1700. Runs cool and don't have to worry about heat. I was mowing yesterday it was 97 degrees outside and my gauge never did get over 190. That's peace of mind to me.
/ For the future #5
My 1602D has a pump (and a 3 cyl engine) but no gauge, just an idiot light. Looking for a good place to mount some gauges soon.(I've seen all the threads of those who have already done so, just evaluating which would be best for my tractor.)
/ For the future #6
I was wondering if you had a number or website for Fredricks. I have a YM1700 that I want to install a water pump on. I just had the engine rebuilt, and I am very nervous about running my 1700 in the 220-230 temp range while bush-hogging in the hot Arkansas weather. I have cleaned everything with the radiator, inside and out, and it runs 190-200 when finish mowing/tilling/plowing, but the combination of heat, tall johnson grass and the bush hog seem to be too much for the thermo-siphon to handle.
Thanks
Westfield Seed Auger (A66408)
Westfield Seed...
Case International 21' Disk Harrow (A64127)
Case International...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
PT Anhydhous Tank (A64127)
PT Anhydhous Tank...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
