Foam filled tires...
/ Foam filled tires... #21
I've seem no flat spots on mine. We already had 500 pounds of weight added to to the front. Many people add much more. I can't see increased wear being an issue unless the equipment is much lighter duty.
/ Foam filled tires... #22
Your asking where to get tires filled. In the USA I recommend Wingfoot They are part of BF Goodrich. They have branches in most every state that do tire filling. In Canada Kal Tires. Use only a major company for this service. Small time operators have been known to add chunks of rubber or other stuff to reduce the amount of the 2 part polyurethane that they put in your tires. Likewise, avoid the do it yourself kits, from online sources and the other homegrown procedures. That stuff is junk. It takes professional equipment & chemicals to do it right.
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
2007 FRAC TANK 500BBL WHEELED (A63569)
2007 FRAC TANK...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A59912)
2010 HINO 268 4X2...
