Foam filled tires...
/ Foam filled tires... #21
I've seem no flat spots on mine. We already had 500 pounds of weight added to to the front. Many people add much more. I can't see increased wear being an issue unless the equipment is much lighter duty.
/ Foam filled tires... #22
Your asking where to get tires filled. In the USA I recommend Wingfoot They are part of BF Goodrich. They have branches in most every state that do tire filling. In Canada Kal Tires. Use only a major company for this service. Small time operators have been known to add chunks of rubber or other stuff to reduce the amount of the 2 part polyurethane that they put in your tires. Likewise, avoid the do it yourself kits, from online sources and the other homegrown procedures. That stuff is junk. It takes professional equipment & chemicals to do it right.
Gradall no crank no start (A61568)
Gradall no crank...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2016 EZ Trail Seed Tender (A64047)
2016 EZ Trail Seed...
HEIN-WERNER TIRE/WHEEL INSTALLER/REMOVER (A63569)
HEIN-WERNER...
2014 KENWORTH T800 MID-ROOF SLEEPER (A63569)
2014 KENWORTH T800...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
