Foam filled front tires?
   / Foam filled front tires? #11
100% is off road. Dirt, grass and brush. I have Black Locust trees and their thorns are brutal, but I also bush hog small trees and their spikey little stumps probably cause most of my flat tires.
I mostly use the tractor for mowing. It has an auger on it right now, but I never had a flat from drilling holes, just mowing with the tractor or clearing the and with the backhoe.
   / Foam filled front tires? #12
On my Kubota B20 had problems with front flats. HD loader and small tires didn’t help. Talked to the Bobcat dealer owner about foam fill. She told me beware there are several kinds of foam and varying techniques. Recommended only one installer and that’s what I used. The filled tires were heavy but surprisingly bouncy off the tractor. More bouncy that the air filled tires. No difference in operation or feel. Enjoyed over twenty years of flat free performance till I upgraded tractor. Cons are price, but paid for over time and a few days for the procedure. They recommended doing new tires.
   / Foam filled front tires? #13
Which foam & installer was used?
   / Foam filled front tires? #14
   / Foam filled front tires? #15
Wish I could remember specifically…30 years ago. A lot grey hair since then. It was by weight or density. They prepared tires and foamed only on Thursday. Could pick up Friday but not to be installed till Monday. Foam machine quite costly to start, stop and clean. Remember the shop did a lot business on big tires. Smelly business.
The Bobcat dealer was adamant about the having the right kind of foam for their customers. Hard foam was hard on equipment and operators. Forklifts, tele-handlers and maybe scrapyards use a higher density foam? I know I would have to again contact the local Bobcat dealer as to where to go. See a lot foam filled skidsteer tires on eBay now.
I run Gemplers bulletproof sealant on the fronts now with good success.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
1959 DODGE D510 DUALLY FLATBED TRUCK (A60430)
1959 DODGE D510...
17501-FL (A56857)
17501-FL (A56857)
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
